Mr. Surfacer
    January 2003
Mr. Surfacer
Posted by ADleitch on Friday, June 6, 2003 5:02 AM
Just received my first ever bottles of Mr. Surfacer. What is the best way to apply? What do I clean the tools with?
Remember D-Day 59th Anniversary today.
Its Better to Burn out than to Fade Away!!!
Posted by Anonymous on Friday, June 6, 2003 9:33 PM
Andy. I apply it many ways, but a toothpick is probably the most common for me. I've used a brush as well. You can thin it with lacquer thinner or acetone if you want to spray it through your airbrush (but clean your airbrush before it has a chance to dry in there...)
I do all clean up with lacquer thinner.
Murray
Posted by BlackWolf3945 on Tuesday, June 24, 2003 11:14 PM
I have a number of brushes that I use for applying Mr.Surfacer, each for a different purpose. Brushing it on is the only effective way that I've found for using this stuff.
Fade to Black...
Posted by RonUSMC on Wednesday, June 25, 2003 2:33 AM
Where did you buy it from and how much?
http://finescalegallery.com Active Kits: 1/48 AM Avenger 1/35 Sd.Kfz 251 Ausf C
    January 2003
Posted by ADleitch on Wednesday, June 25, 2003 4:11 AM
Hi Ron,
Got the Mr Surfacer from www.hlj.com, about 2 bucks a bottle. The site is from Japan run by an American, and have had great service from him.
Posted by RonUSMC on Wednesday, June 25, 2003 4:51 AM
What was the shipping on that and how long did it take?
Its a primer right? also they make a filler?
Posted by BlackWolf3945 on Wednesday, June 25, 2003 5:23 AM
Mr. Surfacer is a filler meant for really small imperfections and gaps, like a typical seam along a fuselage joint. It's a bit easier and more effective to use in that kind of application than putty because it's a liquid and will flow to a certain degree.
Fade to Black...
