PLEASE HELP! Brass, super-glue, heat? Ahhhhhhh!
Posted by Anonymous on Friday, June 6, 2003 8:59 AM
Dear Fellow Modelers,
Tongue [:P]Tongue [:P]Tongue [:P]Tongue [:P]Tongue [:P]
I reach out to you, a brotherhood, I need help. I sure that this has happened to more people then just me.
I have been building something scratch from brass and it consists of many different small pieces. I have been soldering it together, but as you can imagine, I touch the heat to one area to attach one part, as another part falls off over there. AHHHH... I was ready to blow my brains out last night.Dead [xx(]..not really, but I did toss a few parts across the room to make myself feel better!Big Smile [:D]
What do I do? I have it now in seperate major components, but how do I attach them all together now?
Super Glue?
JB Weld?
Wishful Thinking?
Got a trick? Please help me!
Other then me switching to Decaf, what do you think?
PLEASE HELP!!!!!!!!!!!Eight Ball [8]
Posted by Anonymous on Friday, June 6, 2003 2:20 PM
hi , go to a radio spare part store and ask to see a heat sink , they come in several sizes , you solder the first parts together then leave to cool apply the heat sink as close to the first joint as possible and then solder the next one and so on . the heat sink stops the heat from traveling up the brass , good luck , i used to make my own from scrap brass rod and screws , but mine were for full sized jobs in power industry . cheers ian
Posted by Anonymous on Friday, June 6, 2003 8:01 PM
The above tip will help a lot.
Solder comes in diffrerent lead/tin ratios as well, the differance for you is different melting points. Start with the highest and work your way down. sorry I can't tell you the melting point for different mixes.
    January 2003
Posted by leemitcheltree on Saturday, June 7, 2003 8:25 PM
Captain,
The previous two posts have great ideas - I would use them both but I would add one thing - I'd make some sort of jig to hold the assembly in place while all your fabrication was going on - this will help in a couple of ways - it will act (partially) as the heat sink that Ian recommends, plus it will help hold stuff still while you use the soldering iron. If the jig is strong and holds the parts tightly enough, this may hold the parts together even if the solder from one part melts when you add another part.
Also, alligator clips can be used to clamp some bits together and keep them together while you solder.
I'd consider getting one of those clamp/base arrangements that electronics stores sell - it's a heavy-ish base (or a base that's screwed to the desktop) and has several moveable arms that have alligator clips on the ends.
Good luck
LeeTree
Cheers, LeeTree
Remember, Safety Fast!!!
Posted by Anonymous on Saturday, June 7, 2003 9:17 PM
The clamp / base arrangement Lee is talking about is commonly known as "Helping Hands." Aside from soldering, no modeler should be without them. Most even come with a magnifying glass built into them that is also adjustable, and believe me, you may not even need the heat sinks with them. You can pick one up for about $20 at just about any craft store.
Just remember the golden rule of solder: "In quick, out quick." Set the iron to the temp just above where the solder melts, then solder the joint quickly, before the heat spreads too much. Also, if you keep the iron on the solder too long, it becomes brittle.
demono69
Posted by Anonymous on Monday, June 16, 2003 12:24 AM
You could also try a resistance soldering iron, which is an insulated plier handle with tweezer tips. You grip the part you are soldering with the tweezers and press a pedal to apply electric current. It heats up fast but the heat is localized so other things don't fall off. I know that you can find them at www.micromark.com but they can be a bit pricey. Maybe RadioShack?
Posted by gregers on Monday, June 16, 2003 3:08 PM
I can definitly recomend "helping hands" i have 2 in differing sizes also dont try soldering big areas in one go. Like MIG welding just do a bit at a time then that way the job wont heat up as much and melt the other joints or distort the parts. also you could try an apoxy type glue which may be easier than soldering...Gregers
Why torture yourself when life will do it for you?
Posted by seaphoto on Tuesday, June 17, 2003 8:13 PM
A couple of things to add to this thread...
One is that there is a heat sink paste available that you can mold around parts to prevent them from coming apart while soldering nearby. I get mine at Orchard Supply, but welding supply houses would certainly carry it. It can be great when soldering large assemblies.
Perhaps the best suggestion is to add, whenever possible, a mechanical aspect to your brass assemblies - drill holes, pin, slot, or whatever wherever possible. This way, your structure is stable before soldering, which always is a good state of affairs! Even .020 wire can be cupped a bit on end with a grinding wheel to give a bit more purchase on another wire.
HTH
Kurt
Kurt Greiner
Interested in large scale, radio control warships? http://www.warshipmodelsunderway.com
Posted by Anonymous on Tuesday, June 17, 2003 9:24 PM
Along with these other great ideas, you might try putting your piece in the freezer for an hour or two before soldering. If the previous solders are properly done and cured, the welds will not be adversely affected by the temperature, and it will allow you to get the part you're working on up to temp while slowing the transfer of heat to the other parts.
Glenn
Posted by Anonymous on Saturday, June 21, 2003 12:53 PM
Ditto to all the other tips, i.e. heatsinks, fixtures etc. As a 50 year model railroader I have soldered lots of brass on some very intricate parts. Wet rags on adjoining parts is another form of heat sink. Also you might try "TIX" solder which I'm sure is available at Micromark. Most solder has a melting point of around 400-450 degrees. TIX has a melting point around 250 as I recall but is just as strong. I also have a resistance solding unit which does localize the heat, but the work needs to be fixtured generally for best results. Do check out Micromark. Most tips mentioned in the previous answers are available there.
Posted by Anonymous on Saturday, June 21, 2003 1:15 PM
There is a wealth of info here. May it should be retitled "Soldering 101" and made sticky.
Posted by seaphoto on Sunday, June 22, 2003 12:38 AM
On the subject of soldering, one of the best things you can do is to control the amount of solder that flows into the joint - this is one case where less is usually best. For small parts, I use a razor blade and slice off very small sections of solder - perhaps .010 thick. This disc can be further chopped if needed; for example, I find that half a disc is more than sufficent to join two .020 wires together.
Always use some kind of flux too - I prefer liquid to paste, and apply it with those new microbrushes you see in hobby shops these days. Be sure to wash the part off before painting.
Kurt
Kurt Greiner
