panel removal - there has to be an easier way :(
Posted by Anonymous on Sunday, February 27, 2005 10:07 PM
If someone posted a howto on this already sorry. I'm trying to remove the grilles from a panel on my little 1/72 T-55. Here is where i'm at so far:
http://img.photobucket.com/albums/v325/tarmac04/RussianGB/t55_engine_grille.jpg
I figure I can keep drilling holes until its done or drill just a few more and hack at it with an x-acto. Anyone have any tips with this?
Posted by Anonymous on Monday, February 28, 2005 3:46 AM
you are on good way .. few more holes per each side . I cut off panell on my fw 190 without holes .. i just tickened plastic from other side and than vith knife ( and good hand) cut off.
    January 2004
Posted by MusicCity on Monday, February 28, 2005 5:37 AM
If I were doing it, I'd probably drill a couple of larger holes near the center of each panel, cut the divider between the holes out with an X-Acto, and then start using files to cut the panels out. If you are going to drill a bunch of holes to get the panel out, that will certainly work, but I'd recommend moving in toward the center slightly and then using a file to enlarge the panel holes. Going all the way out to the edge with drilled holes can give your hole a scaloped look or cause it to be slightly big by the time you clean up the edges.
Posted by waikong on Monday, February 28, 2005 8:53 AM
I've used a panel scriber (Micromark sells one) and a ruler to creat a deep groove before cutting with an X-acto. If the plastic isn't too thick, scrapting 6-7 times will get you 80% there.
Posted by Anonymous on Monday, February 28, 2005 9:23 AM
Thanks for the replies. I'm still working on it. I'll use the tips and post a pic when I'm done. Now to find some screen to fit inside Smile [:)]Black Eye [B)]
    January 2003
Posted by leemitcheltree on Monday, February 28, 2005 11:16 PM
Yeah, mate -
A straight edge and the back of a number 11 X-Acto blade would do.
Or as the above post says, a jewellers saw would be perfect. It's like a coping saw, but a heckuva lot smaller.
Cheers, LeeTree
Remember, Safety Fast!!!
    July 2003
Posted by zokissima on Tuesday, March 1, 2005 7:41 AM
I tend to just scrape away with a hobby knife, and after a few passes, I increase the pressure. Generally works very well, especially on flat pieces like that shown.
Posted by Anonymous on Tuesday, March 1, 2005 6:50 PM
hmm intersting I have never used a jewelers saw but seen them before. How would you use it for this??? Thread the blade through a hole then attach the bow to it??
Posted by Anonymous on Tuesday, March 1, 2005 8:30 PM
You can drill a starter hole then use silk thread and use it like a saw working real slow, it cuts right thru plastic with little problem from plastic build up.
Posted by Anonymous on Wednesday, March 2, 2005 12:50 PM
QUOTE: Originally posted by Peridexion
A Jeweler's saw would make short work of this. This is just the kind of task they are made for.
I can't believe I forgot about that Banged Head [banghead] Oh well you live and learn ... and forget ... and learn again Sigh [sigh] Anyway here is the end result after drilling more holes and tapping a straight edge razorblade (thin) between. It's all messed up but next time jewelers saw.
Probuilder thats a good idea, kinda like a piece of small cable. Where do you get silk thread BTW? Will dental floss work?
Posted by Anonymous on Wednesday, March 2, 2005 3:15 PM
JoAnn Fabrics should have it, or any fabric/sewing store of repute.
Posted by Anonymous on Tuesday, March 8, 2005 6:57 AM
I tend to use my Dremel/Proxon tool: using a drill as a fraise. The last edges can be done by scraping your knife (exactoblade) or file. But you'd have to have a precision drilling tool (since I got one, I don't ever want to do without: it really speeds up modelling)
Other way for the start is turning your blade in the center on the point of the blade. The further you get, the larger the whole is.
