How to simulate worn canvas, such as the backs of trucks?
    January 2004
Posted by knight667 on Thursday, March 3, 2005 11:13 AM
I tried using pastels, and that seemed to work...until I put my dullcote on. Now you can barely see it. I thought about "heavy" dry-brushing, but wasn't sure if that would work (I'm still not very good at dry-brushing). What do you guys/gals do?
John "The only easy day was yesterday." - US Navy SEALs "Improvise. Adapt. Overcome." - US Marine Corp. "I live each day/Like it's my last/...I never look back" - from "I'm A Rocker" by Judas Priest
    September 2004
Posted by mm23t on Thursday, March 3, 2005 5:53 PM
I use both drybrushing and pastels. Drybrushing just takes pratice. Once you get the hang of it, you'll be drybrushing everythingLaugh [(-D]. When you use pastels, you will want to apply them quite a bit heavier than usual, so the dullcoat will not blow it all away. Hope this helps...good luck. Big Smile [:D]
Medals are not "Won", they are "Earned".
Mike..
    July 2003
Posted by zokissima on Friday, March 4, 2005 8:14 AM
I actually airbrush it. What did you make the canvas out of? I usually tend to scrap the kit pieces, if included, and make it out of glue, paint, and tissue paper. It dries rock hard, and can be painted and weathered well afterwards.
    January 2004
Posted by knight667 on Friday, March 4, 2005 9:54 AM
Yeah, I used the kit piece. It was well detailed, and I sanded it rough prior to painting, and that helped a bit, but didn't have quite the effect I was hoping for. Oh well, I'll do better on the next one.
If I was gonna scratchbuild it (which I've never done), probably a brass rod framework with a tissue paper cover, like you said.Big Smile [:D]
    March 2005
Posted by ephriam01 on Thursday, March 10, 2005 3:08 PM
I'm in the middle of building a Merc L3000 truck and the tissue paper and white glue/water miix works really well.
I use oil paints to show the damaged tarpaulin. Then add heavy washes before dry brushing.
"Cuimhnichibh na suinn nach maireann. Mairidh an cliu beo gu brath."
