I use Squadron's scribing tool. I also have a set of jewelers scribes that work great and some chasing etches. (these latter are not for the squemish and unless you do any type of etching or jewelry work and are familiar with them I would not reccomend them as you push rather than pull like squadrons scribing tool) The tool itself and its technique rely on the sharp edges of the tip and sides. It bites into the plastic and pulls out a furrow. If you drop this or it gets dull, just go out and spend the $8 for a new one. Working with dull or damaged tools is more trouble and the time investment is not worth the frugality nor are the results as good. (If you have ever done woodworking, a sharp chisel or tool is less dangerous than a dull one. And performs beautifuly)
Use a straight edge where possible. I have a few pieces of flexible aluminum or steel that make great guides, contour with shapes and make nice straight lines. I think squadron also offers a metal template for scribing that has different shapes and is flexible.
The scriber does not take alot of effort and if you let the tool do the work it will provide some good results.
In a pinch I have also used the back side of the tip of a #11x-acto blade.
"Imagination is the dye that colors our lives"
Marcus Aurellius
A good friend will come and bail you out of jail...but, a true friend will be sitting next to you saying, "Damn...that was fun!"
