- Member since
Posted by ABARNE
on Monday, March 28, 2005 12:47 AM
In situations with tight clearances, it depends on the exact nature of the problem. Sometimes, I'll use an Exacto blade as a scraper. Depending in the type blade used, you can cet into some awkward areas. Sometimes, I'll superglue a tiny spot of sandpaper to a toothpick. Sometimes, I'll use a tiny dab of putty and work it with the end of a toothpick as it dries. Sometimes a drop of superglue, if carefully applied will go where it needs to go and no require sanding.
