flag
    January 2005
flag
Posted by jinithith2 on Monday, March 28, 2005 7:55 PM
I heard somewhere that sticking an aluminume foil in between the decals results in the wavy look
will this turn out shiny?like metal shiny from the underneath?
Posted by ajlafleche on Tuesday, March 29, 2005 7:04 AM
Short answer, no, if the decal is opaque enough. If in doubt, paint the foil white.
Better yet, download a flag into your photo editor. Make a backside copy. Insert this into a word document as clipart. resize to what you need. Print at the highest resolution onto standard white copy paper and allow the inks to dry several hours at least. Seal the inks with Microscale decal film/decal saver. Allow this to dry. Using a straightedge and a #11, cut the flag out. Crease in the middle. Take some diluted white glue and lightly coat the inside. Wait a couple minutes as the paper absorbs the water and softens. Carefully fold along the You may need to touch crease and roll out any excess. Put furls as you want or drape it on your vehicle. Allow to dry and you have a very realistic flag. You may need to touch up the edges with the appropriate colors.
    January 2005
Posted by jinithith2 on Tuesday, March 29, 2005 8:11 PM
thankyou for the long and very generous reply!
I will absolutely try it!
