- Member since
I wet the model with a solution of warm water & dish soap. Scrub it with an old tooth brush to get any sanding residue out of the panel lines, then rinse under a tap with warm water running. Not actually submerging the model, but it does get pretty wet. Set it on a folded paper towel & let it air dry for several hours before painting. One word of caution, if you used any water soluble glue, like white glue, to attach parts or fill seams, don't use this technique.
Regards, Rick
RICK
At My Age, I've Seen It All, Done It All, But I Don't Remember It All...
