Thinning Humbrol Model Filler
Posted by Anonymous on Monday, April 11, 2005 5:08 AM
can Humbrol's Model Filler be thinned? I need to fill out a lot of small dents and scratches on a large surface, any alternatives to model filler are also welcome.
    August 2004
Posted by jdavidb on Monday, April 11, 2005 5:42 AM
Squeeze out a little bit somewhere and drop some nail polish remover (the acetone kind) in it & mix it around. It works with other putties. Maybe it will work with Humbrol.
Posted by Anonymous on Monday, April 11, 2005 6:13 AM
Thanks, I'll give it a try. Can I just use plain acetone?
    August 2004
Posted by jdavidb on Monday, April 11, 2005 8:48 AM
Maybe, but nail polish remover has the acetone watered down just right to where it won't really rip into plastic while acetone alone is brutal on plastic. I kinda like not having to do the extra step of diluting acetone, so I use nail polish remover.
Posted by Anonymous on Tuesday, April 12, 2005 9:31 AM
OK, that makes sense, I've seen Acetone do it's stuff...
Thanks for your help.
Posted by cmtaylor on Sunday, April 17, 2005 3:46 AM
I find Liquid Poly or Plastic Weld work very well
Gentlemen! You can't fight in here; this is the WAR ROOM!
Posted by Anonymous on Wednesday, April 20, 2005 2:40 PM
Seconded on the glue front, I've used glue from the Revell blue squeezy things to make the putty finer and more "liquidy", but beware, it'll tear through the plastic even worse than just putty itself if you're not careful (as I wasn't).
    July 2003
Posted by KJ200 on Thursday, April 21, 2005 6:33 AM
I always use Liquid Poly as I find this gives the putty not only a finer texture, but also more bite, leading to a better finish.
Karl
