Attaching small parts after spray painting!!
    November 2004
Posted by blackwulf on Monday, April 11, 2005 12:27 PM
Hello Everyone--Hope all is well--I want to get into airbrushing my vehicles and aircraft and was pondering a couple of questions of which I am sure there are a multitude of answers. The questions are as follows:
1.) What is the best way to determine what parts to attach prior to spray painting and the parts that should be attached after spray painting. One of my concerns is that while trying to spray nooks and crannies I might get runs in my paint or other undesirable effects. I realize which obvious parts can be attached--its mainly the little accessories and glass sections on tanks and planes.
2.) If painted prior to application, I assume the paint must be removed prior to gluing onto the body of the model. I use tenax-7r which I think creates the best bond with the least amount of sanding. My concern is that I will create scratches and other marks outside of the object being glued onto the model. What is the best way to cover these up? Use the mixed thinner/paint or is it necessary to make another mix? I was afraid of having differing colors around where the parts are glued on. It may be possible that a wash will cover up any paint color differentials?
I have not been able to find a good article on this process--most articles glance over the small part attachment after spray painting. I have not had the time recently to spend searching on this site for any questions along the same lines. Thanks in advance for any responses.
    April 2005
Posted by JohanT on Monday, April 11, 2005 2:17 PM
Was just about to post in (partly) the same subject.
So I dont have any god answers for you blackwulf, just more questions.
How much detail should be left of until after the dry brushing phase on a tank?
Tools?
Tracks?
Road Wheels?
Have so far built "clean" models,, ie. straight from the box, colours as per instruction sheet, but would like to test some deatiling and whetering?
PS, hope you dont mind blackwulf...Question [?]
    November 2004
Posted by blackwulf on Monday, April 11, 2005 3:48 PM
I don't mind--I'll just learn more!!! GAAAh--My Brain HurtsDead [xx(]
Posted by Anonymous on Monday, April 11, 2005 7:11 PM
I try to build as much as possible before painting. I build the sub-assemblies up until I have to put on parts that will block painting. Just like you said in (1) Blackwulf , this is mostly to avoid runs. I always put little pieces of masking tape at all attachment points of things like axles and wheels before painting. It's tedius but pays off when glueing together.
Posted by Archer1 on Tuesday, April 12, 2005 11:40 AM
Guys -
Very good questions, but you may not like the answer. You do what ever makes sence. Each kit is going to be different, and order might be different on each.. "Generally" if parts are going to be the same color, and should appear to be seamless, I'll assemble first and paint after, but not always. For example. even though large drop tanks are the same color as the ventral side of the A/C, it;'s "usually" easier to spray them separately, then attach them later, for me anyway. I just mask between the locator holes and pins, spray, then remove the masks when ready to glue.
With an airbrush, a little practice can get you off and NOT running in no time. I only use acrylics, and they dry so fast from an air brush, you really have to try hard to get a run!
As far as gluing on paiint, to get a weld, as with Tenex, you'll need plastic to plastic contact, I just use a hobby knife or razor blad to remove the paint. However, if the part isn't weight baring, a touch of CA (Superglue) will bond painted surfaces, so you do have options.
Archer out.
    April 2005
Posted by JohanT on Thursday, April 21, 2005 11:54 AM
Yo blackwulf, here is a Armor link on the subject to...
http://www.finescale.com/fsm/community/forum/topic.asp?TOPIC_ID=40917
    November 2004
Posted by blackwulf on Sunday, May 8, 2005 10:54 AM
Thanks for the help everyone!
