Toothpaste and canopies?
    March 2005
Posted by Aviator on Wednesday, April 13, 2005 6:16 PM
I have heard that you can use toothpaste to polish the canopies of aircraft. Is this true and how is it done?
Posted by Swanny on Wednesday, April 13, 2005 6:57 PM
Yup, it's true. Get some toothpaste that contains baking soda and just use the paste as a rub, wash well afterwards, let dry then dip in Future.
Posted by Anonymous on Thursday, April 14, 2005 1:07 AM
will baking soda-less tpaste do the trick?
Posted by Anonymous on Thursday, April 14, 2005 5:04 AM
Yes and no:
You need a 'bad' brand of toothpaste. Good toothpaste will not sand that well. Good for your teeth, but it will take forever to polish your canopy. I use Tamiya polish paste, which works just as well (on the model; not for brushing teeth; although I never tried).
Posted by Anonymous on Thursday, April 14, 2005 5:24 AM
hehehe... i spose u could get a whole line up of different polishes outta different toothpastes .Big Smile [:D]
ive heard that the stuff old ppl use to clean their dentures is particularly coarse...
Posted by ABARNE on Thursday, April 14, 2005 2:11 PM
For something faster than toothpaste, you can use nail polishing sticks. The one I have has three surfaces and it did a super job with some canopy modifcations. Basically I ground out the inside of a 1/72 Spitfire's canopy hood, so that it would be thin enough to look good posed open. After sanding with various grits of sand paper, I used the three surfaces of the polishing stick as well as little swatches from each surface wrapped around a toothpick to get into the corners. Once I was done with the polishing stick, I finished up with tootpaste, although I don't think the toothpaste really did anything. A dip in Future and the thing looks perfect.
    March 2005
Posted by Aviator on Tuesday, April 19, 2005 10:22 PM
That's kind of weird. Two toothpaste-canopy topics. Sorry about thatTongue [:P]
