flat finish
flat finish
Posted by Anonymous on Sunday, April 17, 2005 1:26 AM
I'm new to this hobby. My last build was in 1986 and the way i got back was when my daughter check out this hobby shop and bought me (3) 1/44 scale WW2 aircraft and that was it, the experience and memory just flame my interest again.. This is an awesome site, i learn alot from you all ,full of infro and pros who love to models. I notice how advance modelling have grown.
One of my question is what kind of flat finish you apply to a WW2 aircraft, either brand name products or any homemade formula. I use acrylic paints and the experience i had on one of my model when using tamiya flat is it went frosty white.
Thanks for you help,
waynenoda
    July 2003
Posted by madmike on Sunday, April 17, 2005 2:22 AM
Tamiya flat is an additive to flatten gloss paints. If you spray it onto your model, it will ruin your finish.
I would recomment Pollyscale flat acrylic clear.
cheers
MikeJ
"I do not feel obliged to believe that the same God who has endowed us with sense, reason, and intellect has intended us to forgo their use." - Galileo Galilei
Posted by maddafinga on Sunday, April 17, 2005 3:19 AM
Yep, that Tamiya flat is a flattening agent, not a flat coat in its own right. If you mix it about 4 parts Future to 1 part flat base you should get a really nice flat coat. Just remember to lightly mist coats on and let the flat build up. It won't turn white that way, but will be a clear flat coat.
Madda Trifles make perfection, but perfection is no trifle. -- Leonardo Da Vinci Tact is for those who lack the wit for sarcasm.--maddafinga
    August 2003
Posted by tweety1 on Sunday, April 17, 2005 5:04 AM
I agree with maddafinga.
I used to use brand name flat finishes, but on heavily weathered aircraft, it still looked to 'satin' in appearance, hence didn't look 'right'.
I made up my own flat finish, and it works like a charm.
Tamiya flat base
Future floor polish
Windex
I dont have ratios, I make a new batch every time I run out, and because you never know when a manufacturer might change their recipe I have chosen to not risk it, and spend a few more minutes mixing, rather than a few hours undoing a total stuff up.
Yes I agree, I have trust issuesApprove [^]
--Sean-- If you are driving at the speed of light and you turn on the headlights, what happens???
    April 2004
Posted by pmm736 on Sunday, April 17, 2005 7:59 AM
Another victim of the dreaded Tamiya flats. They really ought to put a warning label on that stuff.
BTW Sign - Welcome [#welcome]
Posted by Anonymous on Sunday, April 17, 2005 2:12 PM
Thanks again for your help, I'll either try to pick up some polly scale clear or with the tamiya flat i have left I'ii try the formular maddafinga gave.
Much Mahalo
    December 2004
Posted by panzerpilot on Sunday, May 8, 2005 4:51 PM
Whew..almost.!
A good way to ruin my many days work on a Panther G is that Tamiya flat base.
I tried the future mix and there was a definite slight whitening. I brushed some straight future on there and it's back to normal now. I may have put too much flat in it? I think I'll try the poly scale flat now.
-Tom
