Future Floor Polish
Future Floor Polish
Posted by Anonymous on Monday, June 16, 2003 12:53 PM
HELP!!! When using future as a base for decaling do I cover the entire model or just brush it were I a placing the decals? I do not as yet have a air brush, and I am worried that if I brush coat the entire model it will not look right.Question [?]Question [?]
Posted by Anonymous on Monday, June 16, 2003 1:34 PM
hi , only the area you intend the decal to fit , if you do it right and apply only a very thin coat you should have no problems cheers ian
    May 2003
Posted by Martsmodels on Monday, June 16, 2003 3:58 PM
Sorry ! - but why are you using it as a base? with Solvaset, MicroSol, Decal1 and Decal2 you have everything you need. After the decals have dried off completely it can be a good idea to 'set' with Future with a minimum overlap to protect against any adverse reaction to a lacquer but I don't know why you should want to use it as a base.
Have I missed something here? M
Martin http://www.freewebs.com/martsmodels/
    January 2003
Posted by shermanfreak on Monday, June 16, 2003 4:41 PM
Even using the set and sol solutions, decals will sometimes not adhere properly to a flat finish. The procedure I use is to first apply future to the area where the decals are to be located. This gives the decals the necessary gloss finish to adhere to. Followed by decal set then decal sol. To return everything to flat I will spray light coats of dull-cote (2 or 3) until the finish is uniform.
Posted by RonUSMC on Tuesday, June 17, 2003 4:16 AM
I use it as a base to protect the flat finish from being water damaged.
http://finescalegallery.com Active Kits: 1/48 AM Avenger 1/35 Sd.Kfz 251 Ausf C
Posted by djmodels1999 on Tuesday, June 17, 2003 4:38 AM
Unless you have a very rugged, curvy or awkward surface, and provided you'll re-spray the whole thing in gloss or satin or matt varnish, Future does the job of the other products.
