vacuform!
    January 2005
vacuform!
Posted by jinithith2 on Sunday, May 1, 2005 5:29 PM
I have this huge 1/16 scale stuka that is made of wood and vacuform material.
the vacuform edges are round ( the part where the piece joins to the sheet).
what is your technique of the vacuform?
    August 2004
Posted by jdavidb on Sunday, May 1, 2005 9:24 PM
You most likely will have to put little braces inside made from stock styrene rod. You know, kinda make a skeleton/frame to weld the vacuformed parts onto. I don't know for sure without seeing the parts. Whatever it is, you're gonna need putty.
    September 2004
Posted by Borg R3-MC0 on Tuesday, May 3, 2005 8:19 AM
check the vacform group build. It has some links on techniques.
    May 2003
Posted by qmiester on Tuesday, May 3, 2005 6:22 PM
A long, long time ago, when I actually flew models, we would install vacuform or metal formed cowling in the following manner. Once the firewall was ready, we would install a series of 1/4" or larger square blocks of wood around the perimeter of the firewall.They were inset from the edge to allow the cowl to slip over them and go clear to the firewall. Once the set back had been determined, the blocks were filed and sanded until they fit closely inside the cowl when it was up against the firewall and the cowling was secured in place with very small wood screws. If I were building a static model, and using a vacuformed cowl, I would probably secure it in place with Super Glue. Any way that's how we used to do it.
BTW, Who is the manufacturer of your Ju 87?
Quincy
    January 2005
Posted by jinithith2 on Tuesday, May 3, 2005 6:37 PM
guillow makes the stuka
    May 2003
Posted by qmiester on Tuesday, May 3, 2005 6:52 PM
Gad! Someone actually building a balsa and tissue model. The mind boggles!
Quincy
