'speriment TEISE...........
conduct trials......see what works for you
my cuppa tea is stretched sprue for antenna (along with a few other applications)...........reason being.............i can control its thickness.........
application is with CA glue...............
apply the sprue length with a little sag in it (much easier and no need to be so precise)............
once the glue cures............snip the excess ends............
strike a match.......blow it out and while it's smok'in and warm..........run it under the sprue and voila........
the residual heat sneeks up on the sprue and it shrinks just right...............
of course the possibility of the match being too hot is always present........so, 'speriment, 'speriment, 'speriment.........
really works great and sure lasts a long time.........
best 'o luck to ya...........
