Calling Jeff Herne, Calling Jeff Herne!!!
    January 2005
Posted by STUG61 on Friday, May 13, 2005 7:48 PM
Kindly Mr. Herne. I took your advice from another post and got some Citadel inks and paint. You were right on about the metalics.They drybrush like a dream. My question is the inks for wash.How do you dilute them, or do you. I looked for some info as far as what they clean up with and thinner and so forth but as of yet nothing. Your help would be appreciated. Great publication by the way. Thanks in advance.
Smile! It makes people nervous!! Andy
    January 2003
Posted by Jeff Herne on Monday, May 23, 2005 8:38 AM
Sorry for not responding sooner. I don't usually get much time to read everything in all the forums, so your best bet is to email me directly.
I thin the Citadel inks with water, most of the time it's distilled water. Once the ink is down and has dried, you can remove it with any ammonia-based glass cleaner, I typically use Windex or some generic blue cleaner.
What I have noticed is that Windex on a clean brush allows you to blend colors nicely, and can remove the ink even from uncoated flat paint.
Hope that helps!
Jeff
    January 2005
Posted by STUG61 on Monday, May 23, 2005 11:42 AM
Thanks bunches!!!
