Confused
Confused
Posted by Anonymous on Monday, May 16, 2005 1:45 AM
Someone, anybody, somebody.
What's the difference between "wash" & "prime"?
If they are 2 seperate things, which would you prefer?
Wink [;)]
Posted by Anonymous on Monday, May 16, 2005 2:41 AM
they r to comletley different things, with different purposes.
prime: priming parts is painting it with a primer, (a special type of paint, kinda like thinned putty)which servers serveral purposes. it will provide a solid base coat colour for subsequent colour coats, aswell as aiding with adheision of the the paint. it will help u spot surface imperfections, and if any puttying was done, it will provide a uniform surface. it will fill minor scrathes and rough areas. i recewntly have been using mrbase white 1000 as my primer and am very happy with the results.
now, a was is a very diluted paint which u apply to a model to higlight certain thing, such as bolts, panel lines etc... becauswe it is so thin it will run easily where u want it to go. i feel tha enamels are best for wshes.
hope this helps ya out mate!
Posted by Anonymous on Monday, May 16, 2005 2:43 AM
here r some links which will help ya
http://www.swannysmodels.com/Tools.html
http://italianhorses.net/Tutorials/tutorials.htm
Posted by Anonymous on Monday, May 16, 2005 3:14 AM
Thanks, you're the man. Those websites are good too.
So does that mean using emanal paints are good washes? Or is there another type of wash meant solely for washing?
Question [?]
    May 2003
Posted by bud156 on Monday, May 16, 2005 8:54 AM
There are two common types of paint used in modeling(I think). Enamel and Acrylic. Acrylics are water based so they can be thinned and cleaned up with water. Enamel paints need mineral spirits or alcohol to be thinned and cleaned up. I don't think you can by a "wash" in a jar, you have to make it yourself by thinning your paint with the appropriate thinner(water or mineral spirits).
Posted by Anonymous on Monday, May 16, 2005 9:46 AM
Thanks bud156. Big Smile [:D]
I think using a primer would be simplier now. But opinions will change.
Posted by Anonymous on Tuesday, May 17, 2005 2:00 AM
one thing i forgot to mention bout washes..... say u paint ur kit with acryls, use a enamel wash, coz enamel thinners wont lift acrlys, and vice versa. the reason i say this is if u need to remove any excess or a mistake, it wont damage the underlying paint job, if ya know what i mean....
Posted by Anonymous on Tuesday, May 17, 2005 2:12 AM
I've got it. Thanks
Posted by ajlafleche on Tuesday, May 17, 2005 7:17 AM
Perhaps de-natured alcohol, but when most of us think alcohol in this context, we think isoppropyl or rubbing alcohol which will not mix with enamels.
To the main question, I find that artists' oil paint is the best medium for washes. You have better control of the mix and the pigments are the finest available. They also last forever.
Posted by Anonymous on Tuesday, May 17, 2005 8:31 AM
Some of the Citadel paint range (Warhammer) are dedicated washes or inks that can be used in the same fashion. Still might require thinning to taste however.
Posted by Anonymous on Wednesday, May 18, 2005 4:20 AM
Lets say i'm using Tamiya Acrylic's for my plastic painting. Is it necessary to thin the paint before applying them onto my kit?
    September 2004
Posted by Borg R3-MC0 on Wednesday, May 18, 2005 4:27 AM
Yep, thinning is important, else the paint wil be to thick and look like a mess.
I saw a tread on the same subject, I think they sugested a 3:1 paint/thinner ratio in that thread.
Posted by Anonymous on Thursday, May 19, 2005 8:11 AM
Thanks RemcoGrob. Big Smile [:D]
It's now time to get more thinners for this. Tamiya thinners should be suitable for Tamiya acrylic's aren't they? Or someone has a better and cheaper suggestion?
