masking tape seatbelts
    August 2004
Posted by spong on Sunday, May 29, 2005 5:00 AM
How do I use masking tape to create seatbelts for 1/72 aircraft and any ideas for scratch building/painting buckles appreciated.
Cheers
"We copy you down Twank,Tranquillity,You got a bunch of guys about to turn blue,we're breathing again, thanks alot" Charlie Duke Capcom Apollo 11 July 20th 1969
    January 2004
Posted by MusicCity on Sunday, May 29, 2005 4:37 PM
A 2" wide belt in 1/72 scale is going to be only 1/36" wide so masking tape is probably going to be somewhat thick (almost as thick as wide). I'd recommend thin textured foil, such as is found in cigarette packs or on the necks of wine bottles. Either way, cut a strip about 1/32" wide, paint it the proper color, and glue it in place. For wire-style buckles use very thin wire, bend it into the proper shape, and glue it to the "Belt". For solid buckles just use several layers of foil until it is thick enough and then glue it to the belt.
