After some frustration with other masking materials I decided to giev it a try. To say the least the results are great. It sticks really well and can be contoured to just about any surface and then cut the same way like a latex mask. It does create some moments of tension because while removing it makes a sound and feels like pulling on velcro but I've yet to pull of the paint from a model using this method. Just through I'd pass it along and help someone else who might be having some problems.
I usually stuck with Tamiya masking tape but I just wanted something I could wrap around an entire parts and then only cut out the area to be painted.
Hobbico Master Mask is also pretty good but the drying time to begin cutting was too much for me. In any case, is there any surface prep that should be done before applying it. I read soemwhere that it helps to apply a coat of clear flat..
