Plastic "crazing"
Plastic "crazing"
Posted by Anonymous on Tuesday, June 24, 2003 1:10 PM
Just what is it when plastic "crazes"?
Posted by RonUSMC on Tuesday, June 24, 2003 1:11 PM
When it sniffs enough fumes?
http://finescalegallery.com Active Kits: 1/48 AM Avenger 1/35 Sd.Kfz 251 Ausf C
    May 2003
Posted by erush on Tuesday, June 24, 2003 1:21 PM
I'm sure that helped him Ron!Big Smile [:D]
It's when CA, Plastic model, or other types of glue cure they give off fumes from the reaction (to air). These fumes will "craze" or "frost" clear plastic as it etches or eats into the surface. It will also show on colored plastic if enought glue is present. You can minimize it by providing a draft for ventilation, but on clear it's best to use white glue (Elmers) or Future to attach it.
Hope that's more help than Ron's answer, though his was technically correct I supposeBig Smile [:D]
Eric
Hi, I'm Eric and I'm a Modelholic too. I think I have PE poisioning.     "Friendly fire...isn't"
    May 2003
Posted by styrene on Tuesday, June 24, 2003 2:31 PM
Solvents found in laquer paints and associated thinners will also craze bare styrene. That's why it's important to have the model appropriately primed before laying down a laquer topcoat. Evidently, crazing first described fine cracks that appeared in the glazing of pottery. I guess it would be logical to assume that a similarity of sorts exists between the cracks in glazing, and the change in the texture of styrene as it is "attacked" by non-compatible solvent-based materials.
Gip Winecoff
Posted by RonUSMC on Wednesday, June 25, 2003 2:31 AM
lol!
Keep it up and you will see some Ron crazing!
