Squiggly camo?
    January 2004
Squiggly camo?
Posted by knight667 on Tuesday, June 14, 2005 4:29 PM
So on WWII German a/c, how do you guys/gals go about simulating the squiggly-line camo that was used on some of the bombers?
John "The only easy day was yesterday." - US Navy SEALs "Improvise. Adapt. Overcome." - US Marine Corp. "I live each day/Like it's my last/...I never look back" - from "I'm A Rocker" by Judas Priest
    April 2004
Posted by crockett on Tuesday, June 14, 2005 7:23 PM
Well, without going into a lecture, there are as couple of techniques. The most obvious is the freehand airbrush method, which I prefer. You can also reverse mask using mediums such as silly putty and other masking materials. The third option is to cut templates.
Steve
    June 2004
Posted by clfesmire on Wednesday, June 15, 2005 7:03 AM
Unfortunately, there aren't a lot of blueprints available for aircraft. But on armor and trucks, I look for orthographic views of the piece (you know top, side, back & front) print them to scale (this can be the tricky part) and cut out templates for the different colors. A little hint: if you hold the templates only a fraction away from the model, it gives the look of a hand sprayed camo job. This is particularly desirable in more modern pieces.
Posted by waikong on Wednesday, June 15, 2005 12:12 PM
I've seen people who do it freehand with a double action Airbrush. Not me though, don't have to skills (yet!).
    June 2004
Posted by clfesmire on Wednesday, June 15, 2005 9:09 PM
waikong,
Ditto, hence the templates.
    September 2004
Posted by giobosco on Monday, June 20, 2005 4:55 AM
Hi All,
I have done a bf-109 1/72, and of course it's small, but i started with that, and did it free-hand. Experimented first on a piece of paper (lots of experimentations), then I sprayed it, didn't come out too shabby... I would post a pic, but I am still to gind out how....
