QUOTE: Originally posted by jcheung5150
those are great models Brian. can you describe what you do for the weld beads effect w/sprue?
Thanks!
For the welds, I roughly cut a bit of stretched sprue (of a diameter I think is "right" for the weld I want to make), lay it on the places I want the welds to be, then apply Tamiya Super Thin cement. Capillary action glues the bits of sprue down. After cutting off the excess sprue, I go back and cover the whole thing with more Tamiya Super Thin. I wait a second, then use an X-Acto (with a broken tip) to sculpt in the weld bead look into the softened sprue. Looks like a weld to me!
Couldn't be simpler.
Make sure to use Tamiya (or any other brand) Super Thin Cement, since the regular stuff is too thick and will gum up the bead and the surrounding plastic.
Good luck!
