- Member since
I'm just finishing up the Hasegawa P-40E version of the kit. I chose to assemble it per kit instructions. The fit wasn't bad, but I did get a slight step at the join. The join should be filled & sanded smooth in any case, since the join line is not on a panel line that existed on the real Aircraft. Also means you'll likely lose part of the engraved panel lines, but they are easy to rescribe.
Regards, Rick
RICK
At My Age, I've Seen It All, Done It All, But I Don't Remember It All...
