Scribing Lines for the first time
    August 2004
Posted by cj95 on Monday, June 27, 2005 3:46 PM
I'm about to tackle a 1/48 Mig and want to try my hand at rescribing panel lines for the first time.
I've read the various hints and tips on the 'net and kudos to the variosu authors for some grea ideas.
However I have one last question before I break out the knives......
On a kit with raised lines.....if the lines are already in the correct position do I scribe directly ALONGSIDE the existing line, or directly ON TOP of the existing line?
I know Im not supposed to sand off the raised lines unless they are misplaced, but am just not sure EXACTLY where I scibe.
Thanks.
Posted by ckfredrickson on Monday, June 27, 2005 4:10 PM
I scribe on top of the lines.
Part of the answer may depend on who's method and what tools you're using... it may be hard to keep a knife or needle on one of those ridges, but I use a scribing tool that carves out a pretty good, though perhaps too large, gouge.
    April 2005
Posted by wing_nut on Monday, June 27, 2005 10:48 PM
I just re-scribed a good portion of my P-40 fuselage. I read somewhere else in the forum about using Dymo tape, used for making labels as a straight edge. The hard edge to pull the tool against edge and adhesive back to hold it in place worked like a dream. I have the scriber that cuts out a little hair of plastic as you draw it across. I have never tries to go over a raise line before but I would go right over top using the Dymo and scriber. If you set it just right it should take out the raised and leave the engraved. If you miss it a bit try a light buff with a green Scotch Brite scouring pad then wet 600 grit sand. You may need to lightly go over the scribes again with the tool just to clean them up.
Marc
    September 2004
Posted by giobosco on Tuesday, June 28, 2005 4:02 AM
The Dymo works great, guys....it gives a nice "shoulder to lean on" so to speak..
Cheers
Gb
Posted by Swanny on Tuesday, June 28, 2005 8:54 PM
Read this article - should go a long ways towards helping you out.
http://www.swannysmodels.com/Scribing.html
