Panel lines with oils
Posted by Anonymous on Monday, June 27, 2005 10:01 PM
Haven't used oils before and was wondering if anyone could share some techniques for doing panel lines.
Posted by Anonymous on Tuesday, June 28, 2005 10:59 AM
If you want to know how to accentuate panel lines with oils this is done in recessed panel lines, you can look at this tread
http://www.finescale.com/fsm/community/forum/topic.asp?TOPIC_ID=9431
Posted by waikong on Tuesday, June 28, 2005 3:28 PM
I'll add to that link by saying put a clear coat on before you use oil. Especially if you use enamel. I use Future after the base coat is tried. The oil paint will not attach Future. Also you need to clear gloss coat to make sure the oil flow well and any excess can be easily wiped off. Other than that, just remember to dilute well and let the stuff flow into the lines from a small brush.
Posted by Anonymous on Tuesday, June 28, 2005 3:42 PM
Thanks alot guys. Smile [:)]
