Missiles stripes?
    January 2004
Missiles stripes?
Posted by knight667 on Wednesday, July 6, 2005 4:23 PM
What is the best way you guys/gals have found to do missile stripes? I've used masking tape to mark out the areas and then paint the, but I often get bleed-through. I'm considering painting some decal strips and using those. Suggestions?
John "The only easy day was yesterday." - US Navy SEALs "Improvise. Adapt. Overcome." - US Marine Corp. "I live each day/Like it's my last/...I never look back" - from "I'm A Rocker" by Judas Priest
    January 2004
Posted by MusicCity on Wednesday, July 6, 2005 7:37 PM
I mask them and then paint them if there aren't stripe decals provided in the kit. Sometimes I paint them anyway depending on the quality of the decals.
If paint is bleeding under your masking tape something is wrong. It either isn't sticking properly, you aren't burnishing the edges down well enough, or you are putting a ton of paint over it. Paint the edges with Future before painting the color stripe. That way if anything bleeds it is just clear Future.
Posted by Archer1 on Saturday, July 9, 2005 8:45 PM
knight -
Usually air brushing the stripes in dusting coats stops the bleeding. As for me, I cheat. I've been using the Pactra pinstriping tape, it quick and easy. Some folks complain that its too thick for scale, but it's a concession I can live with.
Archer out.
Posted by Anonymous on Sunday, July 10, 2005 12:03 AM
yeah; you can eliminate the bleeding issue by putting either a coat of the base color or clear color first after you mask; this will seal the bleeding crevices and ensure a clean line.
I also like to take a toothpick and really press down the edges; as long as the tape is fresh and not reapplied for any reason; this ussually eliminates 99.9% of any bleeds; the rest are taken care of with that base coat above.
    June 2005
Posted by Sasarchiver on Sunday, July 10, 2005 2:57 PM
whats future? as im getting ready to mask of off my apache but dont want bleed through...regards gordon J
Posted by Anonymous on Sunday, July 10, 2005 10:40 PM
future floor polish, walmart sells it in the cleaning aisle.
http://www.finescale.com/fsm/community/forum/topic.asp?TOPIC_ID=7824
all I care about is you get a big bottle for 5$. I was getting tired of buying tamiya clear gloss for 3$/ounce. way more economical.
    May 2004
Posted by albert_sy2 on Monday, July 11, 2005 2:34 AM
FSM once carried this tip from a reader: thin labelling tape for canopy frames. Works well for missile stripes too I guess.
Groovy baby
