Thinning Squadron Puttys
Posted by Anonymous on Wednesday, July 2, 2003 12:22 PM
I have squadron green putty and want to use it to fill some gaps and I want to thin it to a better consistancy, what can I use to do that and how much?
Posted by wayne baker on Wednesday, July 2, 2003 3:27 PM
Green is toluene based, so toluene would thin it. But it is also very bed for your health. I have used shellac thinner to sand it. I'm not sure if that would thin it. How much? Depends on how thin yuo need.
 I may get so drunk, I have to crawl home. But dammit, I'll crawl like a Marine.
Posted by Anonymous on Thursday, July 3, 2003 8:01 PM
Haven't done it in a while but I think Testors liquid styrene cement is what I used to thin the stuff. And like Wayne said, Green putty is toxic, so use ample ventilation and a respirator wouldn't be a bad idea.
Posted by Anonymous on Sunday, July 6, 2003 11:46 AM
Squadron Green can be thinned using Acetone or Nail polish remover so that it may be brushed on..
Cheers
Posted by Anonymous on Friday, July 18, 2003 9:01 AM
Hi!,
I've thinned Squadron White Putty (same stuff I guess..) sucessfully with acetone. I've used it thin enough to paint into seams and then fine sand after dry. Acetone dries very quickly and breaks down enamels, acrylics and styrene plastic. I use it to clean all my brushes, air brushes, cups, etc. Use gloves, it absorbs into the skin easily..
Posted by Anonymous on Monday, July 21, 2003 2:48 PM
I use denatured alcohol. I find it works better than nail polish removal. I have never gotten it thin enough to paint on, but I am going to try that technique.
Posted by berny13 on Monday, July 21, 2003 10:04 PM
If you thin Sguadron Green putty too much it will crack when dry. I tried thinning it to cover a wing to fusulage seam and after it cured it sunk and cracked. Green putty is best used un-thined. It will still shrink but not as much as when thined
Berny
 Phormer Phantom Phixer
On the bench
Posted by BlackWolf3945 on Saturday, July 26, 2003 3:58 AM
Better yet, use Squadron White. It doesn't shrink as much as Green.
Better still, use Mr Surfacer (for small gaps), CA or two-part auto body putty.
Fade to Black...
