55 Gallon Drums
    July 2005
55 Gallon Drums
Posted by Z_FNQ on Saturday, July 30, 2005 7:48 PM
I want to scratch build some 55 gallon oil drums. Has anyone done this I ahve done a search but come up empty. I was thinking of using thin aluminium sheeting but I need the dimensions of the oil drum. Can anyone help?
Posted by Anonymous on Sunday, July 31, 2005 12:01 AM
why not just buy the tamiya set???
http://www.finescale.com/fsm/community/forum/topic.asp?TOPIC_ID=46616
    July 2005
Posted by Z_FNQ on Sunday, July 31, 2005 12:31 AM
I want to be able to make them in different scales so I need the dimensions of a 1:1 drum.
    July 2003
Posted by Foster7155 on Sunday, July 31, 2005 2:38 AM
A standard 55 gallon steel drum is approximately 23 inches in diameter and 35 inches tall.
Robert Foster
Pensacola Modeleers
    July 2005
Posted by Z_FNQ on Sunday, July 31, 2005 3:56 AM
Thanks Robert - that's all I need to start my experimenting.
    June 2005
Posted by MontanaCowboy on Monday, August 1, 2005 6:25 PM
You can also take 3 soda bottle caps and glue them together so it looks like a drum and sand it smooth or whatever to make it look good.
"You know, Life is like a Rollercoaster. Sometimes you just die unexpectedly." No wait, that's not it.
    July 2005
Posted by Z_FNQ on Tuesday, August 2, 2005 4:35 AM
I want to be able to make the drums in different scales so once I have worked out the sizes I can then replicate them as necessary. I intend to use thin aluminium from a drink can, then use cut off sprue for the bung in the top. If it works out I will post the pics and dimensions etc
