An excellent weathering technique I would like to share
    April 2005
Posted by Tigertankman on Saturday, July 30, 2005 8:57 PM
Hey guys, this is a weathering technique I use, I made it up...
Are there any powdery dirt areas around where you live? If so do the following:
Take some and put it in a bottle with a plastic cap
Poke three holes in that cap
For just dust, simply pour the dirt over the model in big piles everywhere and brush it off, repeat until result desired is reached
For a dirty look, or to make it look like it has been getting dirt splashed on it, do this:
Take some flat coat(from a bottle is nessacary),this will act as an adhesive for the dirt,and brush it all over the horizontal spots of the model
Now pour on the dirt in big piles,brush it off immediatley, when the flatcoat is dry, the brush strokes will show up, leaving the take looking like it has been traveling, so brush the dirt in the correct direction that the dirt has been traveling on the tank, because like I said, you may not see it when the flatcoat is still wet, but when dry, dirt "streak marks" will show up in the direction you brushed it off
Now for dirt buildup:
Start by putting on the flatcoat in the areas where dirt would build up(I.E. fenders, front glacis,bottom of rear glacis....)
Now put dirt on again over the flatcoat
Brush the dirt very LIGHTLY in the direction it would be splashed onto the tank(exceptions would be the rear glacis ONLY)
For dirt on the tracks simply repeat the flatcoat method described above
This method is pretty much permanent(I tried to get some off with water....)so practice on a peice of painted plastic first!
I also used a stipling motion to get the effect seen on the vertical sides of my tiger 1
This is pretty much a weathering technique that I made up as I went along, and I have perfected it since I started doing it, it is actually very, very easy.It is also practically FREE...
Here are some fine examples of the results of my technique
This is heavy dusting with light dirt clumps in certain areas
Heres the "streak mark" method
Heres the result of "packing" dirt into the tracks, I feel it makes them like they are clogged with dried mud. In the background can be seen the extremly heavily weathered StuGIII.
Heres a good example of the stipiling motion (done with a brush) used to simulate dried mud
Heres another example of stipiling, this time on the front
This is the result of this technique put to extremes, the flatcoat works like a charm!
These last two pics show the stipiling motions results
Heres the whole parade! http://photobucket.com/albums/b296/Kingtiger222/
I hope you realize that those are models I have done and that the above mentioned technique does work. I hope you use this technique to your advantage.
Happy modeling!
    August 2004
Posted by Tankmaster7 on Saturday, July 30, 2005 9:23 PM
It looks decent, but IMHO it gives a too uniform finish. Looks like ti's been travelling through the desert or something. For best results i think different tonal variations need to be used to get more realistic results.
Just as a side note, in the third pic, the roadwheels on your tiger look out of kilter.
-Tanky Welcome to the United States of America, a subsidiary of Exxon Mobil Corporation, in partnership with Halliburton. Security for your constitutional rights provided by Blackwater International.
Posted by Anonymous on Saturday, July 30, 2005 11:26 PM
Hey Tigerman,
I really like your weathering technique! I see you live in California. I live in Florida, so I am not sure if my dirt would work as well as your dirt would, is this right?
Perry Lockhart
Shell Point, FL
    April 2005
Posted by Tigertankman on Sunday, July 31, 2005 1:32 AM
That depends on exactly where you live (your property) scout around your property, look for soft powdery dirt, and use that, it should work just fine, best part is you practically have a lifetime supply of weathering powder sitting in your backyard! It would take longer, but If you really want to do this technique, find some way to grind the dirt into a very fine grain, I wouldnt know how, but we are modelers, we always find a way!Big Smile [:D]
    April 2005
Posted by Tigertankman on Sunday, July 31, 2005 1:34 AM
QUOTE: Originally posted by Ju-88C-6
Hey Tigerman,
Oh correction, I'm TigerTANKman, please dont get me confused with tigerman, this happens every now and then, just wanted to let you know
Posted by Anonymous on Monday, August 1, 2005 7:43 AM
Thumbs Up [tup], nice work Alex, And ur 13 yrs old?? Wow!! [wow]
    April 2005
Posted by Tigertankman on Monday, August 1, 2005 9:25 AM
14 in september!Blush [:I]Laugh [(-D]Tongue [:P]
Posted by Anonymous on Monday, August 1, 2005 10:14 AM
Thanks Alex! I didn't know you were 13! I am 17 on Nov. 13 , so we aren't too far apart.
And just thought I might share a little technique of mine also... I always "purify" my dirt I use, generally for dioramas, but now I can also weather with it :-)
I go get some out of my yard, get all of the twigs and such out, and put the pure dirt into the oven and at about 400 degrees for about 4 or 5 hours. Then once out of the oven stick it in the microwave on HIGH for 15 minutes and nuke it! Then take it out and let it coll down for a few minutes, and then get out all the remaining twigs and stuff. Then you have some pretty clean dirt to work with. Hope this helps,
Perry - 16
Shell Point, FL
    April 2005
Posted by Tigertankman on Tuesday, August 2, 2005 12:27 AM
Hey thanks, now I know how to commit genocide on a sub-atomic level!Evil [}:)] But seriously, thanks for the tip!Tongue [:P]
Posted by Anonymous on Tuesday, August 2, 2005 10:53 PM
no problem Alex. And I usually do a big load so it lasts me a long time. I'd say around 3/4 of a gallon or so. take care,
Perry
    June 2004
Posted by clfesmire on Friday, August 5, 2005 4:00 PM
When looking for fine powdery dirt on your property, check out ant hills. The little buggers can't carry large pieces so all around an ant hill is a great supply of fine granules.
