Salt chipping trouble
    March 2005
Posted by Aviator on Friday, August 5, 2005 11:12 AM
Well, I thought I was doing this wright, but I guess not. I painted the wing of my B-24 silver (Tamiya aluminum to be exact) and then proceeded with the salt chipping. This has to be where I goofed.Disapprove [V] I put a few drops of water on the paint (after it had cured a few days, of course) and sprinkled the salt on. I let that dry for a few more days and then painted it. This is what happened.Angry [:(!]
Please tell me this will get covered up with another coat of paint.Sad [:(] I even let it dry for a few more days after I painted it just to make sure I wasn't imagining things. It's still there. Has anyone else had this problem and how do I fix it?Black Eye [B)]
Posted by waikong on Friday, August 5, 2005 12:17 PM
Looks like too much water to me. Also, did you use coarse or kosher salt, 'regular' salt will not work too well. Too soluable.
Posted by Anonymous on Friday, August 5, 2005 1:01 PM
I'm curious - what is "salt chipping" and how is it supposed to work?
    March 2005
Posted by Aviator on Friday, August 5, 2005 1:52 PM
Well this is how it's supposed to work. I've had good luck with it before, though.
http://www.swannysmodels.com/Salting.html
Posted by Anonymous on Friday, August 5, 2005 2:45 PM
Suggest using distilled water. Tap water has many things in it that, after evaporation, could cause problems with paint adhesion in the areas where you still want paint. IMHO Smile [:)]
Posted by rjkplasticmod on Friday, August 5, 2005 2:58 PM
Certainly looks like the salt disolved too much & caused the staining effect. I tested the method using regular table salt on a scrap model & got similar results. Tried it again with the coarser Kosher salt & got better results. But I decided the mess it made & the unpredictable results just wasn't worth the trouble, for me at least.
Regards, Rick
    March 2005
Posted by Aviator on Friday, August 5, 2005 2:59 PM
I'm guessing that another coat of paint would not fix it, would it? No, that would be too easy...
Posted by wayne baker on Friday, August 5, 2005 3:50 PM
It should hide the stain, but you have to get the lumps off first, I think.
 I may get so drunk, I have to crawl home. But dammit, I'll crawl like a Marine.
    February 2005
Posted by RadMax8 on Friday, August 5, 2005 8:00 PM
aviator, many coats will cover it, even then not completely
