- Member since
Posted by berny13
on Friday, July 11, 2003 10:39 PM
Apply the glue in sections. I use fast drying ca and start at the top. I apply about four inches and let it set up. I then keep gluing small sections at a time, pressing the parts together to squeeze out the cement and plastic. After the whole sections are completed I cut or trim off the squeezed out plastic and then check for areas that will require more glue. If there is an opening, I apply the glue from the inside, which cuts down on glue getting on the outside of the model.
Berny
Phormer Phantom Phixer ![](http://i22.photobucket.com/albums/b309/berny13/f102copy.jpg)
On the bench
TF-102A Delta Dagger, 32nd FIS, 54-1370, 1/48 scale. Monogram Pro Modeler with C&H conversion.
Tamiya F-4D Phantom II, 13th TFS, 66-8711, 1/32 scale. F-4 Phantom Group Build.
