Aluminum foil covering
    May 2003
Posted by skipper74134 on Monday, July 14, 2003 12:27 PM
I'm wanting to expand my abilities in adding more realism to my aircraft modeling. I want to use aluminum foil to cover some of my birds, but am at a loss on how to permanently apply this to plastic without damaging the plastic surface. Is there a special product on the market that I'm not aware of?
Posted by Anonymous on Monday, July 14, 2003 1:33 PM
The product you are looking for is called Bare-Metal foil. You can get it in several different 'shades' of chrome as well as gold and black. It comes in a sheet approximately 6" X 11". You just cut off a piece, peel it from the backing paper, and then burnish it on to your model. It is very thin and if you're carefull you can burnish it over curves and everything. I just started using it recently myself and it is excellent stuff.
Ray
Posted by Anonymous on Tuesday, July 15, 2003 9:59 AM
There is also a microscale product for glueing AL foil to stuff. Called something like Foil Adhesive. I have used this many times to adhere regular old aluminum foil to models. Works great with gold foil as well for those pesky US rockets.
Posted by Anonymous on Thursday, July 17, 2003 8:12 PM
There is a section in the how-to or tips section on this website and it explains the process and shows him covering a P-38 and it looks awesome...its at:
http://www.finescale.com/fsm/pdf/foiledlightning.pdf
Posted by Anonymous on Thursday, July 17, 2003 10:04 PM
Bare meatal foil is awesome! I've never seen anything that works as well.
    January 2003
Posted by stinger on Wednesday, July 23, 2003 7:35 PM
Here is the ultimate in aluminum coverings.
http://modelflight.com/can-du.html
Don't laugh, look at the pictures and if anyone has ever doen this I would like to hear from you.
May an Angel be your wingman, and the Sun be always at your six
Posted by wibhi2 on Friday, July 25, 2003 9:24 AM
I am using the microscale adhesive - having a few problems with it. Just haven't tried thinning it with alcohol yet, it's going on okay but has been leaving brush marks. Someone suggested a similar type of glue that artists use for goldleafing that has been working out great (also $5.50 per pint).
Things I've discovered during this process:
1. Don't do petite scribes - the cooking alum. is a bit thick and has very little "stretch" to it.
2. Don't fully assemble the kit except where needed, leave small strips open for the gluing surfaces (wing fillets et such), once glued then cover those areas
3. use panel lines as your overlap joints.
4. overlaps don't need to be much (1/16th or less)
5. Don't use sharp items to bunish - foil rips really easily
6. smaller is better
3d modelling is an option a true mental excercise in frusrtation
Posted by Anonymous on Friday, July 25, 2003 6:11 PM
stinger i used to have one of these planes made out of coke cans! my brother in law got me one for xmas...it was pretty cool...just all hung togther with bends, folds, and strategic lips...it was amazing...it got cruched in my last home improvement project and I just threw it away last month...
