anybody want to know how to do awesome weathering?
    October 2005
Posted by Jaypack55 on Sunday, October 30, 2005 10:56 PM
I have discovered an awesome way to do weathering on aircraft models. I use artist's watercolor paints. They work great for washes, various streaks ad stains, and loads of other stuff! All you need to do is put a drop of dishwashing detergent in to get rid of the surface tension (otherwise it blotches up and looks like crap, ask me how I knowWink [;)]). I started using this technique about 3 years ago, and I'm still using the same set of paints! The application techniques are about the same as using oils, except it dries faster, and you can get a lot more subtlety. best of all, a warm, damp, (and sometimes soapy) paper towel will fix just about any mistake. The only problem I have had is that the paint doesn't seem to like to come off decals (again, ask me how I knowWink [;)]).
-Josh
Current Builds: If I were to list everything I have in progress, it'd take way too long! Some notable inclusions:
Hasegawa 1:48 KI-84
Tamiya 1:48 P-51D (in Iwo Jima long-range escort markings)
4 (yes, four) Tamiya 1:48 F4U-1s (1x -1D, 1x -1A, and 2x -1s)
    June 2005
Posted by smokinguns3 on Sunday, October 30, 2005 11:08 PM
thats y i dont weather my models i have know idea where to start or what to use if i could find an easy way to weather my models id do it more often.
Rob I think i can I think i can
Posted by Anonymous on Monday, October 31, 2005 4:46 AM
hey jaypack, try clear coating your model first,set to dry,then apply your watercolor wash, after that you won't have problems with the w.paint sticking on decals. Happy modeling
    January 2004
Posted by MusicCity on Monday, October 31, 2005 5:57 AM
QUOTE: thats y i dont weather my models i have know idea where to start or what to use if i could find an easy way to weather my models id do it more often.
http://www.swannysmodels.com/Weathering.html
http://www.craigcentral.com/models/wash.asp
    October 2005
Posted by Jaypack55 on Monday, October 31, 2005 12:17 PM
thanks for that little bit. I just recently found out that if you lightly brush over the entire model with a damp paper towel, the paint tends to cover a little better. also, it helps to undercoat your model with clear flat before you weather it.Big Smile [:D]
-Josh
Hasegawa 1:48 KI-84
    August 2005
Posted by eizzle on Saturday, November 5, 2005 11:44 AM
i am gonna have to try this. My daughter has 3 pallets of water color paints, I doubt she would mind if i borrowed a little :)
Colin
 Homer Simpson for president!!!
