Putty Question
Putty Question
Posted by Anonymous on Friday, November 11, 2005 12:47 PM
ATM I am building one of the DML Gen2 figure kits.  In some of the figure there are gaps in between things and they need to be filled.  I saw somewhere that you can use some type of putty to fill the gaps. My question is can I buy this putty at a place like Michaels and what would it be called?  If not what should I buy online.
Thanks,
Blake
Posted by Anonymous on Friday, November 11, 2005 1:38 PM
Tamyia Putty is very good: easy to apply, doesn't attacks the plastic ( as Revell Plasto does ), easy to sand.... Can be found in almost every modelshop.
Also Squadron putty and Milliput seem to be very well...
Cheers,
Jürgen
Posted by Anonymous on Friday, November 11, 2005 2:05 PM
My problem is that I dont have any hobby shops around me that carry much as far as modeling goes.  I would like to get some of this stuff at Michaels so I can finishs the figures instead of having to wait for shipping from the internet.
-Blake
Edit:  All Michaels has is Testors items but im pretty sure they do not have any putty.  If someone knows if they carry different brand/type of putty that would work let me know.
Posted by Anonymous on Saturday, November 12, 2005 12:19 AM
Try using CA super glue. if the gap is too big use some spare styrene to place in between the gaps. when dry, sand the excess ca glue that has hardened. this works for a lot of modelers who dont use putty.
Posted by Anonymous on Saturday, November 12, 2005 7:19 PM
If you have an auot parts store near you, pick up a tube of Bondo spot putty, same stuff as Squadron but cheaper. Use with ventilation.
    October 2005
Posted by looper on Saturday, November 12, 2005 10:50 PM
i have testors contour putty that i bought at hobby lobby. i haven't used it yet though, so i can't comment on it's usefulness.
Andy
Posted by Anonymous on Sunday, November 20, 2005 5:03 PM
Try gap filling CA. Bondo also works, but like any putty, it may shrink. The CA method will not shrink and is very easy to sand down.
    March 2005
Posted by mfsob on Monday, November 21, 2005 10:13 AM
Yes, using superglue and bits of styrene to fill a gap is a good method, IF you sand the excess down promptly. If you wait more than about an hour, the superglue will dry to the consistency of glass, and be a real bear to sand down. And I know this because ... never mind.
Posted by Jeeves on Monday, November 21, 2005 10:22 AM
From a while back, I was given advice on trying something called Porc-A-Fill...it is used to fix chips in porcelain.  You can pick it up at Lowes or Home Depot-- if you use it sparingly it can be an effective filler.  One drawback is it does dry very quickly-- so not a lot of time to fiddle with it-- but I have yet to see any shrinkage afterwards....
