Testor clear cote
Testor clear cote
Posted by Anonymous on Monday, July 21, 2003 11:43 PM
I am using Testors clear cote and the paint is looking cloudy. What am I doing wrong or is it a bad product?
Posted by Anonymous on Wednesday, July 23, 2003 10:52 PM
Dear mrozic,
I had the same results with Testors Dull Coat from the spray can. Is the kind your using from a spray can, or are spraying the stuff from a bottle through an airbrush? I decided to use Microsol clear coats, again, from the can. I get much better results.
Sincerely,
Posted by midnightprowler on Thursday, July 24, 2003 4:38 AM
Sound like you applied it too heavily. Try spraying in lighter coats. That should help, or if airbrushed, it wasn't stirred enough, or if can, not shaken enough.
Lee
Hi, I am Lee, I am a plastiholic.
Co. A, 682 Engineers, Ltchfield, MN, 1980-1986
1 Thessalonians 4:13-18 1 Corinthians 15:51-54
Ask me about Speedway Decals
Posted by Anonymous on Saturday, July 26, 2003 5:06 AM
Thanks for the info. I did use it out of the can and I am going to try using a lighter cote if that does not work I am going to give up on this product. I am sure that I probably put a heavy cote on the car. Thanks again
Posted by Woody on Saturday, July 26, 2003 3:32 PM
Your problem might be high humidity. Try lighter coats, applied in a cool dry room. I would also advise you to shake your spray can frequently while spraying.
" I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way." --John Paul Jones
