Fixing a stupid mistake
    March 2005
Posted by mfsob on Thursday, November 17, 2005 8:32 AM
As I was busily masking off my 1/72 B-25 model for the olive drab coat, I wasn't paying attention to where my fingers were going, and discovered when I was done that I had partially pushed in one of the large side windows ... great. How to get it back in the frame?
After prolonged pondering, I got out my ship building drill set, put the #74 drill in the pin vice and drilled a hole opposite that window, then threaded in a length of 24-gauge wire with the tip filed flat, and pushed the window back flush with the frame. Some Testor's Clear Parts Cement applied with a needle along the edges, a little light pressure from behind with the wire, and the window was fixed. I used the leftover clear cement to plug the small hole I drilled, waited for everything to dry and then proceeded to paint. So far, so good! And for my next trick ...
    August 2005
Posted by eizzle on Thursday, November 17, 2005 10:23 AM
Nice save. I will have to remeber that!
Colin
 Homer Simpson for president!!!
Posted by waikong on Thursday, November 17, 2005 1:51 PM
I've done that, but didn't come up with your clever solution. Thanks.
