Help! Need advice for taking glued pieces apart!
    March 2005
Posted by flippersdad on Wednesday, December 7, 2005 8:15 PM
Oops [oops] I was working on a model and decided that I would thin down the wing a bit, that went fine enough, but after attaching the top of the wing to the bottom I then discovered the that the landing gear housing was interfearing with the fit of the wing top!Banged Head [banghead] I never noticed that fit problem during the test fits. My question is this: What do I use to remove the top of the wing from the bottom? I used the Testors Liquid Cement to glue them together. Thanks in advance.
Cheers,
Eric
A great lie - "I'm from the FAA and I'm here to help." Politics - Many blood sucking insects. Flying - Long periods of boredom puncuated by moments of stark terror.
    December 2004
Posted by Hippy-Ed on Wednesday, December 7, 2005 9:42 PM
Laugh [(-D] I just did something similar... I used nail Polish remover (a tip I found somewhere in here) I had inadvertently super-glued a resin piece in backwards Sign - Oops [#oops] I took a brush & ran it along the seams, let it set a few seconds before runnin' the backside of a #11 blade acrossed it. I added another dose of polish remover & put a little pressure against it while I scraped it with the blade.
be gentle with it tho...
hth
Eddie
If you lose your sense of humor, you've lost everything
