what kind of primer ???
Posted by Anonymous on Saturday, December 10, 2005 11:35 PM
i need to know what kind of primer(spray can type) do i use to be able to paint over a metal gun tube with Tamiya paint ts3 (spray can) and camo over with Testor Model Master acryl???
thanks this is my first super detail TIGER I ,i want to do it right(cant afford to mess up)
thanks from ucla
    May 2003
Posted by qmiester on Sunday, December 11, 2005 8:01 AM
My personal preference is regular automotive primer in grey.  It's cheap, one can will do several models and if allowed to dry properly prior to application of color coats, almost any paint can be applied over it without any problems.
Quincy
    February 2004
Posted by RichardI on Monday, December 12, 2005 7:52 AM
qmiester: Have you sprayed acrylics over top? The idea of a rattle can for primer really sounds good to me - I won't have to load up (and clean) my airbrush. I use Tamiya acrylics.
Thanks,
Rich Cool [8D]
On the bench: 1/48 Revell PBY Catalina 0A-10A. Next up: Moebius 1/24 Chariot from Lost in Space.
    July 2005
Posted by clairnet_person on Monday, December 12, 2005 10:51 PM
You can use Games-Workshop white or black primer they are extremely fast drying like you'll be able to paint within 15mins 30 to be on the safe side after priming and they're good for plastic, metal, resin etc etc Tamiya primer is good too but the Games-Workshop I believe is  $15 CDN and the Tamiya is about $10 for a can 25% smaller so the Games-Workshop for me is more economical.
Thats my My 2 cents [2c]
Current builds: Monogram P-40B Revell F-15E
    May 2005
Posted by Ron Smith on Tuesday, December 13, 2005 10:24 AM
I hate rattle cans so I use three primers depending on my mood and the surface I'm priming. I mostly use Alclad grey primer since it's airbrush ready. Next in amount of use if Mr. Surfacer 1000 thinned with Mr. Color thinner. Lastly is Dupont 301 automotive primer thinned with industrial lacquer thinner....smallest available size is one quart and only available at professional autobody supply places. The Dupont primer is an acrylic lacquer and I only use it for masters intended for resin casting.
