Glueing canopies
    February 2004
Glueing canopies
Posted by RichardI on Friday, December 23, 2005 11:23 AM
Does anyone have a really good method for glueing canopies in place? I'm using Testor's white glue in the little black container and I have found that it really doesn't stick very well. I understand that normal tube type glue will fog the canopy and so will CA. What do you guys recommend?
Thanks,
Rich Cool [8D]
On the bench: 1/48 Revell PBY Catalina 0A-10A. Next up: Moebius 1/24 Chariot from Lost in Space.
    May 2003
Posted by qmiester on Friday, December 23, 2005 11:50 AM
I myself usually use standard old Elmers white glue and never really had any problems.  I understand if you dip the canopy in Future, you can install it with CA and not have to worry about fogging - I haven't tried it as I'm satisfied with the white glue.
Quincy
Posted by Anonymous on Friday, December 23, 2005 2:11 PM
Elmers white glue. It's good unless you drop the plane on the ground.....then you've got some problems...Smile [:)]
    May 2005
Posted by Ron Smith on Saturday, December 24, 2005 12:21 AM
If the fit is tight and the canopy is open I use either Tamiya or testors liquid cement. If the fit is sloppy r the canopy closed I use either watch crystal cement or "odorless" CA.
    July 2005
Posted by clairnet_person on Saturday, December 24, 2005 1:16 PM
Apparently the Testors whit glue is supposed to be stronger than Elmers white glue but I can't really prve it since I've never used the Testors stuff.
Current builds: Monogram P-40B Revell F-15E
