seat belt widths?
    October 2004
seat belt widths?
Posted by jschlechty on Wednesday, December 28, 2005 10:42 AM
I've  searched and gotten a lot of info from this site on how to MAKE seatbelts, but I was wondering if anybody new the approximate widths they should be in for 1/48 and 1/72 WWII fighters?  I saw one post that said "cut them 'til they look about the right width", but that's all I found.
Also, a lot of people mentioned painting them after installing them on the seat.  Wouldn't it be easier to and less of a chance of getting paint on the seat if you painted them seperately, then installed them?
    April 2005
Posted by T_Terrific on Wednesday, December 28, 2005 11:14 AM
To try to intellegently answer you questions:
  1. Since the average seat-belt is about 1-1/2 to 2" wide, 1/48 scale would make them about 0.8 to 1mm, 1/72 would make them about 0.5 to 0.7mm. I think this is why the average modeler, like myself, says "That looks about right" and quits while he is ahead.
  2. The question about painting them before or after can depend on how the paint affects the material you are painting (whether it is enamel or acrylic), whether you make them out of paper, sheet styrene, metal, etc., and also how bending the belts to fit affects thr paint, which can crack, peel, chip, etc.
I would figure by the time you got through touching them up after fitting them, you might just as well wait to paint them until after you have fitted them. I mean this is not like painting an ammo belt, where you can have as many as three colors for the belt in question, when you include the brass cases.
As far as paint on the seat, it should be simple enough to touch-up with a small brush.
At least that would be my perspective.
Cowboy [C):-)]
Tom TCowboy
“Failure is the opportunity to begin again more intelligently.”-Henry Ford
"Except in the fundamentals, think and let think"- J. Wesley
"I am impatient with stupidity, my people have learned to live without it"-Klaatu: "The Day the Earth Stood Still"
"All my men believe in God, they are ordered to"-Adolph Hitler
    October 2004
Posted by jschlechty on Wednesday, December 28, 2005 6:30 PM
Thank you Mr. Terrific,
I knew there was probably a mathmatical way to figure it out, but I'm not real good with numbers - I usually manage to screw soemthing up.  I appreciate you taking the time to make the calculations for me! (And will assume they are correct, of course!)
Thanks again!
    May 2003
Posted by qmiester on Wednesday, December 28, 2005 7:31 PM
I would point out that in US Military aircraft, the aircrew have both a lapbelt and shoulder harness.  The shoulder harness is the same width as the seat belts/shoulder harness installed in civilian aircraft and cars - aprox 2" width.  The seat belt is aprox 4" wide w/a one handed quick release which releases both belt and harness.  If the aircraft is configured to carry passengers, their seat belts and harnesses are both the 2" width with a smaller quick release handle.
Quincy
    May 2004
Posted by albert_sy2 on Thursday, December 29, 2005 5:45 AM
How about jet fighter planes? Specifically, ACES II ejection seat harnesses? In 1/48 scale?
Groovy baby
