Bare Metal Foil - Help
Posted by Anonymous on Thursday, December 29, 2005 2:52 PM
I've successfully used BMF on areas that are flat or gently curved. However, when I try to use it to give the right effect on an hydraulic piston the diameter is so small that I can't seem to get the foil to adhere to the plastic. Any suggestions?
Posted by Anonymous on Saturday, December 31, 2005 12:21 PM
is the BMF process like putting on decorative gold foil?  If i remember correctly craftsmen usually brush coat an object with some gin (no joke) for better adheasion to wood and stuff.
    January 2003
Posted by CNicoll on Tuesday, January 3, 2006 9:58 PM
I've not had much success either on such small items.  And when I do get it close to right, it just seems too bright for the scale anyway.  You might want to try Metalizer Paint, polished aluminum and do the polishing with a Q-Tip.  Good Luck,  Chris
On the bench:  Academy 1/72 B-17G 'Blue Hen Chick';  1/48 Tamiya Mustang III; Kitty Hawk 1/32 P-39.
Completed:  1/48 Tamiya P-51D Mustang - 'Show Bird', 1/32 Dragon P-51D  Flying Tigers 'What if'; 1/32 Tamiya P-51D Big Beautiful Doll
Group build:1/48 Tamiya Mustang III; 1/48 Tamiya P-51D Show Bird
