Airbrush question(s)
Posted by Anonymous on Tuesday, July 29, 2003 4:41 PM
I have a couple of airbrush questions...
1) Is getting the compressed air can worth it? I only probaly make one model every 1 or 2 months.
2)which airbrush AND compressor can i get together for under 200 bux?
3)Are double action airbrushes a HUGE improvement over single action?
Thanks in Advance, BTW nice magazine FSM.
Posted by Anonymous on Tuesday, July 29, 2003 5:14 PM
1. No
2?
3. No
    January 2003
Posted by shermanfreak on Tuesday, July 29, 2003 5:45 PM
First off, seeing as this is your first post to FSM, welcome to the forums.
OK ... now for your questions
1) Not really .... you'll go through 1 or 2 cans per model anyway. A compressor will supply you with a constant and controlled flow of air where as the cans don't.
2) Depending on where you live (Canada, U.S., somewhere else). You can pick up a single action Paasche Airbrush for $69 in some locations in the U.S. Add to that a compressor from Wal-Mart or any good hardware store for between $99 and $129. By using a small industrial compressor you have the option of more uses around the house while a hobby compressor is pretty much limited in it's usage. Final things to make sure you have are a regulator (which sometimes comes with an industrial compressor) and a moisture trap (very important and costs about $10).
3) Depends on what you want to paint. I only use a single action airbrush for painting my armour kits. I can achieve the camo looks that I want to do so I really haven't found a need for a dual action unit yet. Also the learning curve with a single action is much smaller.
Posted by Anonymous on Tuesday, July 29, 2003 8:06 PM
Hey thanks Umax5555 and a special thanks to ShermanFreak.
Posted by Anonymous on Tuesday, August 5, 2003 3:42 AM
I went to home depot and picked up an air tank (5 gallons) and a regulator, total cost: about 40 bucks. My schedule for completion of kits is the same as you, I find that the tank holds enough air to complete 1 - 1/48 scale airplane. when it is empty I just fill it up at the station.
My airbrush is..... forgive me, an aztek It works well enough if you take care of it, and their customer support is excellent, my A320 went kaput so I sent it back and they replaced it, no questions asked. hope this will help
    January 2003
Posted by Hoser on Friday, August 8, 2003 12:21 PM
Check eBay. There are always airbrushes and compressors out there - some for way cheap. I have seen ab / comp sets go for less than $50, if you dont mind a used set up.
"Trust no one; even those people you know and trust." - Jack S. Margolis
Posted by dubix88 on Friday, August 8, 2003 1:13 PM
HEY,
I agree with hoser. That is where i am going to get mine at.
Randy
THATS MY VOTE "If a woman has to choose between catching a fly ball and saving infant's life, she will choose to save the infant's life without even considering if there is a man on base." -Dave Barry In the words of the great Larry the Cable Guy, "GIT-R-DONE!!!"
