Hi,
vinyl has its tricks, you can bond with superglue, to get a best fit warm the elements with a hair blower (vinyl gets soft when heated)
To trim pars soft them in hot water, so you could use your hobby knife easier.
To fill gaps you can use superglue for the smaller ones and epoxy putty for larger ones.
Before painting, you must wash the surface to get rid offthe release agent they put on the molds. Then its highly recommended to prime the kit, it will help the paint to set in.
You must use acrilics or another water based paint. You can use enamels ONLY if you use them in a very small areas and over a painted surface.
If you use enamels over vinyl it wont dry and become sticky FOREVER!!!!
