Hey unknown,
When I assemble my a/c, I use Tenax-7R. Basically its a welding glue that has to be applied to both pieces inorder to work(it melts the plastic together).
This is also what I use to fill in any seams that the Tenax did not get the first time around.
If the seams are a bit bigger or deeper(hope not
![Tongue [:P]](/FSM/CS/emoticons/icon_smile_tongue.gif)
), I use Squadron Putty(whiteish in color) or Mr Putty. These both work fine but Mr Putty tends to be a stronger filler once dry.
I have also heard that you can use super glue as a filler as well. I myself had to use it once or twice so I cant really comment on that method.
Anyways the methods described above work very well for me and I feel comfortable using them.
Hope this helps ya out a bit.
Flaps up, Mike
If you would listen to everybody about the inaccuracies, most of the kits on your shelf would not have been built Too Close For Guns, Switching To Finger
