metalizer sealer
metalizer sealer
Posted by Anonymous on Friday, August 15, 2003 10:39 PM
If I put metalizer sealer on a model that has been sprayed with metalizer will I be able to mask over it.
Posted by Anonymous on Saturday, August 16, 2003 4:20 AM
I you use something that is low-tack ("sticky-ness"), such as post it notes, it can be done. Experiment with it first. Cover some other kit part (inside of a wing, part from a kit you won't build, unused part, etc.) that resembles the surface you are trying to mask, and paint it similarly (same # of coats of paint & sealer). If you use a large area for testing this, you can try different materials to find what works best for you. I usually use drafting tape or post it notes. You can reduce the "tack " on a piece of tape by applying/removing it from your skin, but the results are less consistent. Hope this helps !
Posted by Butz on Saturday, August 16, 2003 5:02 PM
Hey csmall,
You could also use "non porose" surgical tape(3M). It too has a low tack plus it can conform to most shapes.
Just check out your local hospital supply store for this tape.
Either way you would not go wrong.
Flaps up, Mike
  If you would listen to everybody about the inaccuracies, most of the kits on your shelf would not have been built Too Close For Guns, Switching To Finger
