Stencils instead of decals
Posted by Anonymous on Wednesday, September 3, 2003 10:04 PM
This is the very best place to ask this question. What do all the scale modelers think about painting on the markings instad of using decals? Like stars and bars,German cross,sawtikas even lets say numbers on the tail of 1/72 or 1/48 aircraft. I,myself would rather use my airbrush to paint on as much of the model markings as possible. Please, I would really appericate aii the feedback you would like to post.
Thanks
Posted by djmodels1999 on Thursday, September 4, 2003 2:02 AM
Honestly, on aircraft, I do not mind using decals, although on my airliners, I do use a lot of dots, stripes and letters/numbers from rub-on transfer sheets. It's on AFVs that I paint stuff on. Because I work at the smaller scales, I often find decals to be too thick or else they won't fit properly onto the busy surface of the kit. Stars would be the only type of markings I'd do differently, again using dry transfers rather than decals.
Posted by J-Hulk on Thursday, September 4, 2003 7:33 AM
Hi, Ratboy!Smile [:)]
I gave stencils a try for the first time on the last kit I finished, Dragon's E-100:
[/img]
Just a couple of simple numbers, but I really liked the way it turned out, and it was very simple to do.
I used the "German Numbers, Large" set from Eduard. They make all kinds of masks and stencils for armor and aircraft, but you could really use anything!
Just becareful and go light on the coats. I got a bit heavy on one side and had a wee bit of seepage I had to clean up later.
Give it a shot!Big Smile [:D]
~Brian
Posted by Anonymous on Thursday, September 4, 2003 11:22 AM
If you prefer stenciling do it, on some older kits with thick decals it is almost necessary. There are stencils availablr from several sources or you can make your own.
