CUTTING PANELS
CUTTING PANELS
Posted by fish on Thursday, September 4, 2003 3:16 PM
WHAT TIPS DO YOU HAVE FOR CUTTING PANELS IN AIRCRAFT TO DISPLAY INTERIOR DETAIL. FROM WALRUSMAN. THANKSQuestion [?]
Posted by Anonymous on Thursday, September 4, 2003 3:27 PM
Welcome to the forum, fish.
First, please turn off your caps-lock. Do you really want to yell at everyone your first day out?
Asfor your question, lightly score around the panel you wish to remove using the back "spine" of a #11 blade, making each pass slightly deeper than the last. It takes time, but you will eventually cut through the plastic. Hope it helps.
demono69
    June 2003
Posted by allan on Thursday, September 4, 2003 8:48 PM
Hey there Fish,
I drill several holes about 1mm from the edge of the panel I intend to remove, then cut along it (sort of like connecting the dots) and punch the panel out. I then use an X-Acto knife to shave off the remaining plastic right up to edges of the panel and thereafter sand the same.
Hope this helps.
No bucks, no Buck Rogers
Posted by fish on Friday, September 5, 2003 8:10 AM
Sorry for the caps. Do you replace the panel with styrene?
