t.p. canvas
t.p. canvas
Posted by Anonymous on Sunday, October 5, 2003 5:55 PM
Alright. I'm not very good at scratchbuilding and I needed to make a canvas roof (the kit canvas was too thick and unrealistic) for a WWII German cargo halftrack. I experimented with some plastic stuff I bought but had terrible luck in sculpting it. I gave up and retreated to my 'fortress of solitude' to ponder my prdicament. While pondering I noticed the texture of the toiletpaper and decided to try using it on my model. After some experimenting and absolutely no luck with draping the t.p. to simulate canvas, I decided to get some water. During the experimenting I spilled the water on some t.p. Later, when the t.p. was dry, I went back to my model and noticed how the t.p. had hardened. Ion the end I came up with this:
- Moisten a strip of t.p. that suits the size of canvas to be simulated.
- Drape the t.p. over the area to recieve canvas and form to simulate drooping fabric.
- Let the t.p. dry so it is completely hardened.
- Carefully remove the t.p. from it's position (make sure it doesn't lose form) so you may finish the model.
- Paint and weather than glue to the model.
This works good for making sandbags and blankets also. The only real problem I found was that the t.p. detereorates when painted with brushes, so this won't work without an airbrush (weathering worls because the base coat of paint protects the t.p.). So try it out and let me know what you think of this.
Posted by Swanny on Sunday, October 5, 2003 6:45 PM
Find some cheap paper towels, not the quilted kind, soak it in dilute white glue and hang on framework for correct shape - let dry then trim and paint.
Posted by Anonymous on Sunday, October 5, 2003 6:48 PM
That sounds good to. i posted this because I wasn't sure if there was information on it anywhere else.
Posted by Swanny on Sunday, October 5, 2003 6:56 PM
Tissue is good for some stuff, I did the shell bags for the top gun turret on my PB4Y-1 with it (that's the one in my signiture) but sometimes you just need to work with a stronger base material.
Posted by Anonymous on Thursday, October 9, 2003 2:50 PM
Went to hobby Lobby and got some muslin (not the same as a dead Iraqui!!). Has a very tight weave. Shot it w/ a quick coat of spray paint to "Hlod" it, then shaped it before shooting it again. Works well and cheap!
Posted by Anonymous on Thursday, October 9, 2003 3:02 PM
I've been using Canopy Wipes (ask those in the Aviation Community.) They hold their shape well, are sturdy when painted, and lots of places will just throw them away after using, so you can get them cheap. Check out your local airport service terminal, they should have some.
demono69
