Metal Figures -- technique for shiny metal
Posted by David Voss on Wednesday, October 29, 2003 11:18 AM
I'm supposed to be working, but I snuck in here to post a quick question.... Wink [;)]
I have read something about this somewhere, but I can't recall where or what book/magazine.
When dealing with metal figures with metal armor and shields, I thought I've seen where people have polished the metal on the figures rather than painting over it. I tried polishing up a sword on one of my metal figures and it doesn't look too bad -- all nice and shiny. A bit more and maybe I could even have an edge on it.
While the blade looks nice, I have a couple of questions/thoughts.
-- Would the clear lacquer protect it from dulling over time and touching?
-- Would it look 'silly' if the rest of the fig is painted?
-- Should I paint it to be consistant with the rest of the fig?
-- Does anyone know of a reference (article, site, etc.) for polishing metal figs?
As always, thanks for your help. Cool [8D]
Dave, as the beginner modeler (not the forum guy) Wink [;)]
David Voss Senior Web Developer Kalmbach Publishing Co. Join me on the FSM Map
Posted by echolmberg on Wednesday, October 29, 2003 12:52 PM
Hi Dave,
As a person who builds 99.9% U.S. WW2 aircraft, I thought I'd take a break and I worked on a couple of metal fantasy figures. One had battle axe. After painting, detailing and weathering the figure I was all done with it except for the metal axe blade. After giving it much thought I finally decided to just leave it as is. I decided that based on something someone once said about bare metal foil on a model: "Nothing looks more like metal than metal." I didn't overcoat it with anything. I just left it as is and I am very happy with it. I'm sure that this string will now be filled with people slamming that idea as it tends to happen a lot after I put my two cents in. But anyway, that's why I left the blade "as is" and untouched.
Eric
    January 2003
Posted by shermanfreak on Wednesday, October 29, 2003 1:22 PM
Something else you might want to try David is burnishing the metal with graphite. I've used this technique with my armour models and am very happy with the result. I just grind enough pencil lead for the project at hand, stick my finger in it and rub the area that I want metalized. Try it, a cheap and easy technique that I think you might like the results from.
Posted by Anonymous on Wednesday, October 29, 2003 1:44 PM
I've tried the metal polishing before, and was quite satisfied with the result. I've never seen any article describing a "proper" way of doing it, though. I just used a bit of sandpaper until I got the desired sheen, then threw a coat of clear gloss over it to protect it. After 10 years, it still looks shiny.
demono69
Posted by David Voss on Wednesday, October 29, 2003 1:50 PM
Eric -- Thanks for the reply. "Nothing looks more like metal than metal." -- I can't argue with that. I think I'll try it and leave it as metal. Of course I'll try to polish it a bit more.
Robert -- I'll give it a try. The only question I have is what's the purpose of the graphite -- is it primarly meant as a polishing agent and do I clean it off when I'm done? Or does it also serve as a weathering material?
Posted by Anonymous on Wednesday, October 29, 2003 4:38 PM
Ive done quite a few figures which had metal weapons with them. A method I use is paint the entire metal part with flat black. Once its dry , using the wire brush in my moto tool I go over the whole thing to remove most of the paint and shine it up. The purpose of the black is it remains in the crooks and crannies to give it that old metal dirty used look. And it helps to bring out some of the detail thats in the swords. You can use a dullcoat over it if youd like. If you notice, most metal weapons ( medieval etc) are worn and a bit dull from the weather and rough use. The only part really shiny is where they sharpen it quite often.
Posted by Anonymous on Wednesday, October 29, 2003 10:19 PM
David,
Try burnishing the piece you want to shine with a sewing needle.
Clean up the part as you normally would. You may even try a brass brush in your dremel tool. or 0000 steel wool. Then burnish it with a needle, by rubbing the piece with the side of the needle. It will bring it to a high sheen.
    January 2003
Posted by shermanfreak on Wednesday, October 29, 2003 10:31 PM
David - I guess you could say it serves as both a polishing and a wethring agent. It certainly gives a glossy yet weathered look to anything that I've worked on. And you don't need to wash it off, it gets to stay.
Posted by berny13 on Wednesday, October 29, 2003 11:20 PM
I used Micro Mesh polishing cloths to polish a white metal prop blade on a kit once. The final outcome looked like chrome. I did not seal it in any way after I was finished. That was over ten yeats ago and it is still chrome looking. It has been touched hundreds of times and has not dulled a bit or got finger prints on it.
Berny
 Phormer Phantom Phixer
On the bench
Posted by David Voss on Thursday, October 30, 2003 1:46 PM
I wanted to try the graphite last night, but I wasn't able to. It's Mike's (renarts) fault. Wink [;)]
Great information though. Thanks guys.
Posted by djmodels1999 on Thursday, October 30, 2003 3:13 PM
I use graphite over flat black to give weapons a 'steely' look. It also worked well on Lords of the Rings plastic figures (also primed black) for chainmail and stuff like that.
The best metal on figures I've ever seen was always the real, unpainted metal. I'd put a thin coat of Future over it to protect it from corrosion though!
Posted by David Voss on Thursday, October 30, 2003 3:26 PM
I've seen the technique of priming figures in black and then drybrushing over the armor with silver or related color. I would like to try the graphite once. I imagine it'll look different than drybrushing.
So many things to try now. Big Smile [:D]
    January 2003
Posted by shermanfreak on Thursday, October 30, 2003 3:33 PM
He didn't write another of his manifestos again last night did he?
Sign - Dots [#dots]
