Hand brushing camo on armor
    November 2003
Posted by rudedog on Saturday, August 29, 2015 5:11 PM
After a 2 year plus sabatical due to caring for an elderly parent & preparing for relocation,I can finally get back to building.Near all my stuff is packed away & I hadda build something.I'm doing a Panther In a 3 color scheme & don't have use of my airbrushing equip.So I'm gonna attempt to the Red brown & Dk.green By hand. The new forum no longer has a search feature That I can find,as I'm sure it's been asked before.So I appolgize for the redundency.I laid down Base w/ a rattle can of Tamiya Dk.yellow & am using Tamiya acryl's for the other 2 colors.Is there merit in using retarder to slow & help level any brush strokes ? Also,I'm guessing thinning would help also.If the retarder is a good idea,how much in proposion to paint & thinner ? I'd thank & appreciate any tips. keith r.
"...That's an order,not a debate topic , Sergeant Rudzik..."
    July 2004
Posted by stikpusher on Saturday, August 29, 2015 6:53 PM
Yes, using a retarder, or better yet Tamiya thinner will help immensely for hand brushing. It is gonna be trial and error to get a mix ratio, but a start point of around 1 part thinner to 4 or 5 parts paint should work. After that, just imagine yourself as a small scale tanker camo painting the vehicle with a brush, broom, I or whatever is available to do the job. Perfection is not the point- concealment is.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    November 2003
Posted by rudedog on Sunday, August 30, 2015 7:18 AM
Thanks,stikpusher.I needed a jumping off point [ no pun intended ! ]. Especially with the ratios. At worst, a little weathering should help,too.  keith r.
    December 2011
Posted by Chrisk-k on Sunday, August 30, 2015 4:49 PM
The Tamiya thinner already contains a retarder.  But you can add more retarder to completely remove brush strokes.  I'm not sure if a regular acrylic retarder will work for Tamiya which is alcohol-based.  Tamiya sells its own acrylic retarder.  I have two bottles of Tamiya retarder and haven't even opened them.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    November 2003
Posted by rudedog on Sunday, August 30, 2015 5:13 PM
Never new that [ about Tamiya thinner ]. Thanks for adding on to stikpushers reply.Like you, I bought retarder many years ago, never using it, when I was new to airbrushing.Turned out it was lack of experience that even retarder wouldn't have helped.Once I'm done moving & have my gear all unpacked,I'll go back to spraying.But I'm kinda psyched to see if I can pull this old school hand brushing off in a decent manner. I view it as yet another learning experience that will translate into better figure painting as well. Thanks, keith r.
    July 2004
Posted by stikpusher on Sunday, August 30, 2015 5:17 PM
Oops... sorry I forgot to mention about the retarder stuff already being in the Tamiya thinner... Embarrassed I knew that I missed something... Oops
       - Plankton
LSM
    November 2003
Posted by rudedog on Sunday, August 30, 2015 6:20 PM
As long as you remember to " hook up" before exiting the 130 or chinook, the rest doesn't matter !!!  keith r.
    November 2008
Posted by plasticjunkie on Sunday, August 30, 2015 7:11 PM
I have tried hand brushing Tamiya acrylics and the results did not go well, even when thinning it with the Tamiya thinner.
I get better results hand brushing with Vallejo.
 GIFMaker.org_jy_Ayj_O
    July 2004
Posted by stikpusher on Sunday, August 30, 2015 11:52 PM
rudedog
"Hook up" is one I have yet to miss.... unlike the Duke in The Green Berets... Wink
       - Plankton
LSM
